jneubauer
So, after heavy rain I get water from the sunroof dripping down the right-front pillar, and onto the front passenger seat.
The last time this happened, I got an air compressor, and managed to blow out the line - or maybe it stopped raining hard.
A couple of questions:
1. Where is the exit to the drain located? Is it in the rear wheel well, like older models? Is there a diagram or picture of it?
2. Assuming that I can find the exit point, can I access it, to try to clear it?
3. Is there a "coupling" in the pillar (or elsewhere) that could be disconnected, and is a problem only when it rains hard? If so, where exactly is it located, and how do you access it?
