2011 Equinox won’t start
terasuu
I have a 2011 equinox ls 2.4l and it randomly starting saying service stability trac system, reduced power as I was going into a parking spot. I turned the car off and now it just won’t start anymore. I had to get it towed home. I don’t know a whole lot about vehicles, but I tried replacing the battery just to see if that could’ve been an issue but it didn’t work.
Heres a video of what it does when I try to start it
Uluz2a6
I'm betting the timing chain stretched (causing the engine light and other warnings on dash) and finally jumped enough teeth to allowimg pistons to collide with valves and bending them.
You need to perform a compression test.if you have a AAA and can get towed again for free, take to a shop for this diagnosis. If not able to get a free tow, you could call a mobile mechanic service to do it.
If you are in Las Vegas I will do for free
mjwalsh74
Buy or borrow an code scanner. This is a classic symptom of a bad throttle body. Easy job to perform yourself!
mjwalsh74
Same exact thing happened to my neighbors equinox, same messages on screen, dealer replaced the throttle body and all good. Just waiting for it to happen to my equinox…
