Key stuck in ignition
upnorthmom66
I have a 2010 and a 2015 equinox. I put the 2010 key in the ‘15 ignition and it’s stuck. It comes half way out. I jiggled and wiggled and googled but nothing is working. Any ideas?
TopHat
Sounds like the same problem the Chevy Cobalt had. Long story short, a guy working for GM changed the design without telling his colleagues and it eventually failed. Cobalt's had a recall and the engineer fired. You might check for recall, or even hidden recall to see if dealer will replace mechanism. I even had a bit of problems with a 2002 Avalanche but always eventually got the key out.
I just found this, it might be helpful: https://www.fixautousa.com/blog/car-key-stuck-in-ignition/#:~:text=Use your left index finger,your key out of it. I also found this and looks like Equinox not included in ignition recall:
What vehicles are included in the GM ignition switch recall?
Which vehicles are involved? All 2003-2007 Saturn ION, 2005-2010 Chevrolet Cobalt, 2006-2011 Chevrolet HHR, 2007-2010 Pontiac G5, 2006-2010 Pontiac Solstice and 2007-2010 Saturn Sky.
Chowboy
same thing continues to happen with my 07. On my 07, there is small square panel that pops out and gives access undereath the column. There is a button that can be depressed with your thumb to allow the key to be removed without issues. Ill try and find the youtube video for ya
upnorthmom66
Thank you!
Thank you!
