One thing I did learn, if you can get the center grill bar
out, then everything else is easy as pie after that. My
kit came from DDM Tuning. (Same place my 3500 Crew
kit came from) and was all plug and play. I had to hook
up 2 ground wires and the 1 battery wire and that's it.
(I also removed the DRL fuse to the maximize bulb life)
I went with the 35w, since our headlight housings are
clear & reflect well, ordered 6K White. (Same as Crew)
