2013 Equinox stuck in park
Chevylove1993
Went to leave for work, car started no problem went to place in reverse and the gear shifter would not move. No check engine light on brake sensor and lights come on. No warning sign. Drove fine the day before. There is a clicking noise when I try and shift as if something not catching but just won't move. Please help!!
NOX4ME
turn the key to to the first position; this will unlock the steering wheel. Do not turn the key to ON with the engine OFF. Be sure that the E-brake is engaged. Depress the brake pedal as hard as possible then move the shifter to neutral. You should be able to start the engine. Sounds like the neutral safety is malfunctioning.
No Tyme
Bryan, Ohio
Curious to know what was the issue. I had this happen once in a truck and it turned out to be a $15 safety switch on the brake pedal.
