4th Gen : 2025 + Current Chevy Equinox
General Chevy Equinox Discussions
Sterrimg wheel shifts left
<blockquote data-quote="Dick&amp;Cheryl" data-source="post: 31006" data-attributes="member: 12138"><p>If the problem is on acceleration from a stop, it could be torque steer or the action of the lane keeping assist "helping" you. I have noticed those things on ours as well. I read somewhere that GM is investigating complaints of that feeling from multiple customers. If the problem is when just driving straight down the road, an old mechanics trick is to switch the front tires from side to side and see if that makes any difference. Of course be sure the tires are inflated to the correct pressure and the same pressure. Our 2026 seems to be especially sensitive to tire pressure. Good Luck!</p></blockquote><p></p>
[QUOTE="Dick&Cheryl, post: 31006, member: 12138"] If the problem is on acceleration from a stop, it could be torque steer or the action of the lane keeping assist "helping" you. I have noticed those things on ours as well. I read somewhere that GM is investigating complaints of that feeling from multiple customers. If the problem is when just driving straight down the road, an old mechanics trick is to switch the front tires from side to side and see if that makes any difference. Of course be sure the tires are inflated to the correct pressure and the same pressure. Our 2026 seems to be especially sensitive to tire pressure. Good Luck! [/QUOTE]
