2018-2024 Equinox Maintenance
Rear differential oil
<blockquote data-quote="Brian-Nj" data-source="post: 29173" data-attributes="member: 6577"><p>So you used the same oil in transfer case and rear differential. And just added the limited slip additive to rear diff? And Thanks for the heads up on the clutch reservoir Gonna do transfer case and rear differential this weekend and I’ll take a look at that for maybe next oil change .</p></blockquote><p></p>
[QUOTE="Brian-Nj, post: 29173, member: 6577"] So you used the same oil in transfer case and rear differential. And just added the limited slip additive to rear diff? And Thanks for the heads up on the clutch reservoir Gonna do transfer case and rear differential this weekend and I’ll take a look at that for maybe next oil change . [/QUOTE]
