Chevy Equinox Engine & Performance
2019 Equinox 2.0T light engine shudder in park- MAP maybe?
<blockquote data-quote="4549stiltz" data-source="post: 29064" data-attributes="member: 10919"><p>I would find a scanner that reads live data. Then check the fuel trims to verify if engine is running correctly. It sounds like it might be running a little lean by your description. Yes, I seen lots of engine running lean and sometimes it is hard to find out why. I retired from a Chevrolet dealer and that was my line of work Run ability.. Good luck.</p></blockquote><p></p>
[QUOTE="4549stiltz, post: 29064, member: 10919"] I would find a scanner that reads live data. Then check the fuel trims to verify if engine is running correctly. It sounds like it might be running a little lean by your description. Yes, I seen lots of engine running lean and sometimes it is hard to find out why. I retired from a Chevrolet dealer and that was my line of work Run ability.. Good luck. [/QUOTE]
