When you change your oil....
Admin
Do you wait foreever trying to get that last drop of old oil out before replacing it with new?
I changed my oil in the nox and while its draining I plan other work to try and get as much out.
What do you do?
Lenn
Beaumont, TX
I change it every 5k with Mobil1 synthetic. I also usually run half a quart or so of ATF for a few miles just to get all those detergents run thru the engine. I usually used Motorcraft filters when I had my F150 and a Mobil filter on the Mazda6. Probably going to use it on the Nox too.
The next oil change, I am going to use a jug of Valvoline NextGen that I got for free from Autozone.
Sent from my Droid using Tapatalk
Drummerjohn
South Dakota
Just changed the oil with AMS oil 0W-30 and wix filter. Instead of waiting I flush with some clean oil, just enough to get the cruddy stuff out of the bottom. I don't wait for the last drop whe I do this, makes the oil change go faster and I know th sludge at the bottom reduced.
Z_Ghost
Super Mod
Texas
Been doing that for a long time, always have a few quarts around so I can dump one down the pipe.
Faison NC
Lets be realistic here everyone. You have brand new vehicles and maintain them well, you should not have "crud" inside to flush out. Now if it was a used vehicle and it had 100k miles on it yeah maybe. But I would bet an AMSOIL oil change that if you stuck a borescope inside the oil pan it would look nice and clean.
Admin
Hey Nick, you know the saying "whatever helps you sleep better at night" that's what I am going for, peace of mind.
prheaume
Sherbrooke,Qc
One of my friend used an engine cleaner on his dad's chevy venture and it blew the engine off, how to make a dad upset in three easy steps haha
oleg1981
Brossard, QC
i just changed my oil changing every 5000km. my truck had oil consumption about 1l per 5000km. but last 2 changes i used castrol gtx high milage and oil consumption is down to ~0.5-0.6l per 5000k. a and i hit already 155000km :)
prheaume
Sherbrooke,Qc
An oil consomption is considered normal by the manufacturer if it stays lower than 1L per oil change.
Here at BMW we often put 1L per oil change cycle (oil service are 1 year / 25 000 km here ). Only the M series cannot exceed that as they use 10W60 instead of 5W30.
