09 Equinox. I had a water hose leak. Replaced. Radiator leak. Mechanic replaced. Also replaced the thermostat and temperature system.
I have to keep putting water in it. Runs fine for a few miles, then begins to over heat. I spent a week trying to bleed out the air through the bleed valve near the water pump. There is no water in the oil, and no steam coming out of the tail pipe.
Just this morning, I went about 4 miles in it before it began overheating. I stopped. The fill well showed 3/4 full. I opened the air bleeder, steam coming out there. So I gently loosened the cap on the fill bowl, It starts bubbling violently, and blowing water out the overflow. I put a gallon of water in it, blead off the air, and managed to make it home.
This cooling system, in my opinion, is a monster.
HELP???
HELP???
