I also had a similar error and it appeared after replacing the air filter. most likely due to the fact (in my case, anyway) that when replacing the filter it was inconvenient to unscrew the cover of the filter box and I had to unfasten the connector of the mass air flow sensor. apparently subsequently unreliably snapped the sensor connector and there was an error. opened - closed (connector) and the error went away after the reset and did not appear for more than 10,000 km.Hello all, has anyone had trouble with their mass airflow sensor and/or throttle body? My car has about 50,000 miles and it was getting code P1101, thanks!
