DLS
- Joined
- Apr 18, 2023
- Messages
- 3
- Reaction score
- 0
3.4 engine. Fans run when needed, new reservoir bottle, new thermostat. Can drive 6-8 miles and starts to show overheating. Give the motor a rev up to 3000 and let off and temp goes back to normal, drive more happens again. That sounds like air in system. Belt be slipping on the waterpump pulley? I’ve spent hours bleeding air out via bleeder bolt and adding more antifreeze. Next is water pump I guess. Had car in the shop for a miss and they said the head gaskets tested to be fine. Replaced spark plugs, runs fine now besides this overheating. Oil is fine as well. No milky appearance. If water is shooting into the top of the reservoir corner via the 1/2 hose, is that coming from the water pump?
Thanks. I need this car running badly for daughter and her baby to get to work and back.
