Rear end vibration
This is a discussion on Rear end vibration within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
Hi to all! Long time since I came here, being busy with the job but still alive in the summer ...
Old 12-28-2014, 06:13 PM   #1 (permalink)
Default Rear end vibration
Hi to all!
in the summer I noticed a vibration in the back of the truck. It was minor but there. I suspected that I lost a weight on the rear wheels. In Novembre I install brand new winter tires on my second wheel set, the vibration was worst than ever! I balanced the wheel again, vibration is still there but lower, but a 60 miles you can see a change in the voice (funny haha).
Looked with a tech at the dealership where I work, nothing loose, we will have to take the driveshaft appart to see if it's a joint or the center bearing that is bad.
According to GM, the joint can't be replaced, according to a shop I know, the joint can easily be replaced by some ATV joint with greasable tip.
I'll keep you updated of the work performed so you can replace them if you notice something in the future.
thanks
Pascal
Old 12-29-2014, 03:04 AM   #2 (permalink)
Good to hear from you! Keep us updated!
Sent from my XT1254
Old 12-30-2014, 10:50 PM   #3 (permalink)
Sent from my XT1254
Hey man! was a long time! Been busy with the work and stuff around. The dealer where I work was bought by a big group of dealers, wnt trough some audits and everything, rought 2014, happy to see 2015 coming
Old 01-11-2015, 06:30 PM   #4 (permalink)
End up with a bad u-joint, found one on Napa, too big, 2005-06 Nox have bigger joints than 07-09, my nox is FWD since I found a solution. Might end up with a new one on rock auto
Old 01-13-2015, 08:33 PM   #5 (permalink)
Installed my new drive shaft from Rock auto. Back with AWD
Old 03-17-2015, 10:30 PM   #6 (permalink)
I bet that is a nice feeling!
Old 11-22-2015, 12:53 PM   #7 (permalink)
brandy is on a distinguished road
Default problem fixed?
So a new drive shaft fixed the vibration? I've been replacing stuff like crazy to try to get rid of that vibration. I'm running out of money to buy uneeded parts. Was thinking maybe about the driveshaft center support bearing.
brandy is offline   Reply With Quote
Old 01-04-2016, 11:22 AM   #8 (permalink)
But it also could just be the U-joint.
Old 05-27-2016, 08:00 PM   #9 (permalink)
thuzmund is on a distinguished road
The u joint and driveshaft bearing are often replaced together, and probably ought to be if you're pulling it all apart anyway, so you can consider those two halves of the same repair if that helps the math work out to your favor.
thuzmund is offline   Reply With Quote
Rear Doors Don't Always Unlock jklemick 2010+ Equinox General Forum 0 05-10-2014 03:46 PM
FS: $70 Rear shade NEW from Equinox jecilop Classified: For Sale/Wanted 2 09-09-2013 06:14 PM
Rear washer pump solericardo 05-09 Equinox General Forum 1 03-15-2013 06:01 PM
Thumping in Rear CBod 2010+ Equinox General Forum 0 02-20-2013 05:29 PM
No rear air?? renee Interior Modifications 7 07-19-2010 01:21 PM
