P0496 Help
This is a discussion on P0496 Help within the 05-09 Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
Check engine light is on with P0496 code. I've replaced the gas cap and no change. Looking to see what ...
Old 04-17-2017, 12:50 PM   #1 (permalink)
08equinox is on a distinguished road
Default P0496 Help
Check engine light is on with P0496 code. I've replaced the gas cap and no change. Looking to see what to try next. I'd rather not have to take it to the shop. Any help is appreciated.
08equinox is offline   Reply With Quote
Old 12-17-2017, 09:19 AM   #2 (permalink)
Colt Hero is on a distinguished road
You’ve probably fixed this by now, but on my 2011 V6 it was the EVAP Purge Valve behind/under the Throttle Body near the firewall. About $35. One 10mm bolt. Had to remove “accordion” tube/pipe coming off the air box, then reach around and under with ratchet using 3” extension and socket. There’s a single power plug on it, and the valve itself simply “plugs into” a bore/hole.
The 2008 is probably slightly different.
2011 1LT Nox
3.0L V6
Pioneer, 18"
~ 74,000 mi (3/26/15)
Colt Hero is offline   Reply With Quote
2012 V6 Evap Solenoid ( P0496 ) SorcierX 2010+ Equinox Maintenance 0 09-17-2016 02:14 PM
