-   -   Ball Joint (http://www.chevyequinoxforum.com/f37/ball-joint-1311/)
BionicBo 03-22-2015 09:34 AM
Ball Joint
i had to take off steering knuckle to remove what's looks to be original hub on a '05 when I used a pickle fork to pop the lower ball joint (which looked original aswell) I noticed the clearish grease starting to leak I don't see any damage to boot so I don't know if I wrecked it but I was thinking of replacing just in case, my question is are they pressed in or should it pop out easy enough once I drill out the rivets, I don't want drill out if I'm not going to be able to remove it from control arm.
BionicBo 03-25-2015 03:46 PM
Found my answer just went ahead and did it, very easy
dietz4ibanez 03-27-2015 11:40 PM
Nice! I had a hub in a Saturn Vue that was so rusted that I had to take the control arm somewhere to have it pressed.
