Go Back   Chevy Equinox Forum | GMC Terrain Forum | Cadillac SRX Forum > Chevy Equinox Forum > New Member Introduction
Hello from Ohio
This is a discussion on Hello from Ohio within the New Member Introduction forums, part of the Chevy Equinox Forum category!
Hello! I recently purchased a 2015 Chevy Equinox with the 2.4 Ecotec and AWD. The car has a little over ...
Old 02-22-2019, 11:19 PM   #1 (permalink)
chips90 is on a distinguished road
Default Hello from Ohio
The car has a little over 40k miles on it and everything looks like new. The only issue is that when I did the oil change ( second day after purchase ) the oil was black and thick...
I replaced the oil with 5w30 Valvoline synthetic dexos and a high quality oil filter.
I know the ecotec is known to have some issues with the timing chain tensioner when the engine is run with dirty oil.
The only way to tell if the timing chain is loose from my understanding (without taking the engine apart) is to listen the engine while starting when cold - it does make a bunch of noise when is starting cold but I can't tell if it's normal or if it's a issue...
The car doesn't have any OBD codes or pending codes for that matter.
My question is, should I be worried about the timing chain ? Are there going to be some signs if it's on it's way out?
chips90 is offline   Reply With Quote
New from Ohio kwOH New Member Introduction 1 04-01-2020 02:46 AM
New from Ohio Matts3sons New Member Introduction 0 07-13-2018 01:25 AM
New from Ohio airdvr1227 New Member Introduction 2 08-28-2015 08:19 PM
Greetings from Ohio Camaro69car New Member Introduction 11 03-24-2015 05:49 PM
New Member from Ohio TheDarkKnightKnox New Member Introduction 5 05-01-2012 08:39 PM
