Water leak in 2018 trunk.
clake87
I've noticed that when it rains that the mat in the trunk is wet and little puddles form in the corners. I found the ceiling of the trunk was like this and is wet.
Do you have a sunroof? If so it is leaking. I just caulked my sunroof shut. Mine went to the dealer twice. The first time they replaced a drain. the second time they said it was clogged from debris. I questioned it and they said it is a bad design. the drains are too small. I gave up and caulked it shut. No leaks for me.
p.s. check your spare tire well. I'll bet is is wet, too.
AmmoJoe
I don’t know if you did it or it came that way but the headliner is supposed to be tucked under the gasket.
