New guy but did this today.
Not too dificult the back ones suck a little bit.
You really don't need any special tools. Just the correct size spark plug wrench, flat tipped screw driver, ratchet and various extensions.
You have to remove the oil cap, filler tube and EGR connector. The connector is where you will use the screw driver.
EGR connector, you have to get the screw driver in there to release it.
Remove the beauty, sound deading cover. It will look like this. It will just pull off.
The front ones are easy. Plenty of room
The rear ones? No so much, but not the worst I have ever done.
You do most of it blind.
You can do some of it by going between the subframe and engine or moving behind the subframe and going up from there.
Looking up between the engine and the subframe, the plugs and wire
are on the topside of the rear exhaust manifold.
Pretty straight foward plenty of room on the backside, just hard to see.
Took me about 2 hours and got right about 70 bucks with all OEM parts from Rockauto.
