High pressure fuel pump
bhotz
I have a 2011 equinox has a 2.4 rough idle at stop lights some hesitation when you take off continues to run after you turn the key off but there is no fuel in the oil.
ThePapaJohn
Richmond, KY
A few things come to mind:
Malfunctioning injector (s)
Incorrect timing (easy check)
Buildup of carbon in the cylinder (pull your spark plugs [one at a time] and a quick peek might reveal)
These are the leading causes these days for gasoline engines to have a "dieseling" problem.
With you having a rough idle and hesitation to boot, sounds like a timing issue. How many miles on it? When were the plugs/wires last changed? (I've lost count on how many times I have come over to someone's house that attempted to DYI a poor man's tuneup - and miss wired - causing this problem....
Update info always appreciated ~ even if you fixed it on your own...
