Backup Camera
Rbicard
I have 2012 Equinox LT, recently purchased this vehicle. Battery went dead, when I replaced the battery the Backup Camera is not working. I did check the fuse in the engine compartment, it seems to be good. While in reverse message on the screen says check your surroundings but NO picture,
Randy
SteveK
Have you tried a factory reset in the radio settings. Of course you will lose any you have set. I did that and mirror tilt and seat vibrate alert started to work.
Rbicard
Thanks for the suggestion, i did try that and it did not make a difference.
SteveK
I have 3 locations for fuses. Engine comp, under dash and rear driver side.
The camera module fuse is under the dash driver side F40.
Rbicard
I will take a look at the additional locations, thank you!!
