Wiring running lights
4549stiltz
Washinton
I'm setting up a 2024 Equinox to flat tow behind my Motorhome. My question is what wiring system did the DIY folks use. I have incandescent bulbs. I really did not want to cut into the wire harness. This is my last step to finish to tow. My Motorhome has separate brake and turn signal. I am thinking I will need a 5 to 4 diode assembly. I need some ideas please. Thank you.
Moonwink
SW of St Louis, MO
Maybe these links will help give you some ideas:
I've tried changing the color for this text but this site likes black text. Sorry.
As an Amazon Associate we earn from qualifying purchases.
4549stiltz
Washinton
These link would not open for me Yes, I seen curts kit it looks pretty simple. Thanks
Moonwink
SW of St Louis, MO
I had one installed on my 2015 Malibu. It's works great. I also had a Blue Ox base plate installed. I want to use a ReadyBrake system for the brakes but the shop that did the other work claimed they couldn't find a path for the brake cable. Up to now, I've always done all this work myself. I guess I'll be crawling under there again to finish the job. ☹️
4549stiltz
Washinton
Yes, I do all my own work but age is catching up with me so time will tell. Thank You and good luck on your installation.
DCR
Alaska
i set up my 2022 Equinox for flat towing. I used all Roadmaster parts. They have a web site that you type in the year, make & model of car/truck and they tell you what parts you need. Their base plate looks like factory equipment after it is installed. I highly recommend the Roadmaster equipment.
4549stiltz
Washinton
Thank You, I used Blue Ox Brackets because I already had a Blue Ox tow bar. That is interesting on what they use to wire the tail/turn lights.
