Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
already done - didn't fix the issue, checked the wiring on the sensor harness and checked for air on the bleeder screws in case an air bubble was causing it to go off
Had stuck open thermo on my 07 torrent. Scan tool said motor was 155f. And code was for coolant temp too low and coolant temp too high. P0126 and p0128? Been awhile. New thermo is at 200-205f when fans come on and then go off. then I had lousy heat at idle. But ok heat driving. Flushing heater core fixed that.
