Transmission issues
OKE
We have a 2010. Bought it new. 158K now. 4 cyl. Automatic. After a bit of warm weather driving it does not want to engage reverse gear. One click up to park and back again will usually get reverse to engage. Any ideas about the cause? Also, at normal speed, there is a slight hesitation between gears. Thought maybe the two clues together you smart guys/gals out there. Thanks!
comp
has the fluid been changed? valve may be trying to stick
OKE
I’m hopeful it is old fluid. I’ll suggest the valve possibility to our mechanic. Thanks!
comp
good luck,,,im going to use manuel mode a few times before the next drain and fill to move more valves
