trailer electrical connection?
gib
I recently bought a 2011 lt it has a drawtite to hitch but I do not see an electrical connector.
? Is there a factory connection somewhere I should dig out OR do I have to tap into the wiring without that headstart?
Thanks in advance,
gib
dougmac
Thanks in advance,
gib
This one should plug right into the factory harness. 2010 and older require a body controller reflash. You should be good with a 2011. On the factory installations, the harness is fed through the center of the rubber drain bung in the spare tire well. The video suggest running it through the tailgate, which seem a little sketchy to me.
https://www.etrailer.com/Custom-Fit-Vehicle-Wiring/Chevrolet/Equinox/2011/118264.html?vehicleid=20111170703
