Left Front Turn Signal Working Intermittently
Gene62
Nofolk.VA
Our 2024 Equinox has a frustrating issue with the front left turn signal.....Occasionally, it will not work and we get a message on the dash that tells us the Right Front Indicator is not Working.... I've replaced the bulb 3 times in the last 5 months...... all yesterday afternoon it would not work, so I decided to work on it when I got home from work, and when I pulled into the garage it was working....first time all day it had worked.....now when we backed out to go to work this morning.....it was not working again.........then at lunch time today it was working......and so on........................... What gives?
Big Papi
Check connections and grounds. Wring diagrams with connector locations can be had with a temporary service manual subscription to ALLDATA
RIT333
If you have under 36k miles, and 3 years, then it should be fully covered under the BtB warranty.
RIT333
Then you would have to pay. Time to learn how to debug electrical circuits. Google will be very helpful.
Member Recommended
