K&n intake and jet maf installed on 2017 equinox midnight edition
I got the k&n air intake installed with the jet performance maf. It runs strong. I can definitely tell there is an increase in power. f786f99c8401c269c5e0decf0be4bca0.jpg
Sent from my SM-G930V using Tapatalk
aerona87
Is it required to install a new MAF if you install the CAI?
Fitter30
The air box are thoughts open slots at the top before or after the filter.
aerona87
Yeah, I guess I should have worded my question a little better. Is the Jet performance MAF worth $200? How does it actually do all of these things? How can it increase air flow since it doesn't control air coming in. It measures density and tells the engine how much fuel to add.
  • The JET Performance Power-Flow increases airflow up to 45%
  • Works by flashing a fit-tested, factory-original sensor with advanced programming
  • Increases fuel economy, low-end torque and horsepower
