Just an FYI about 8 spd transmissions
Defflin
Kentucky
Sounds like all the 2025 and 2026 Equinox with the 8 speed trans have the same 8th gear problem. Is there any thought about a class action lawsuit since it was advertised as having 8 gears but only seven are used.
Seems like they should be 1. It appears to just be a programing glitch. So easily fixed but they choose not to address the problem. Ive opened numerous cases with GM and all they do is close them.
GaryM
Couple folks have..Not sure where that went. Lemon law was one suggestion. I'd like to get the thing fixed but modifying my driving helped quite a bit. But there are times when the "normal" TCM code we're all used to would smooth things out.
Dick&Cheryl
It does use 8th gear below 60 mph. Check out engineering explained video on you tube regarding the operation of small Turbocharged engines with relatively high compression and running on 87 octane fuel and how they handle high temperature pre-ignition. (Spark knock or pinging in the old days) that may help explain the transmission programing. Ours now has just over 7000 miles and mileage has improved to 32.5 mpg on the highway running 73 mph in 7th gear.
