Heat Settings with Factory Remote Start
agleavesrn
I have a LTZ Equinox 2012 with factory remote start. Is there a way for the heat to come on when you remote start the car? The other day I had it started for 10 minutes on a very cold day. When I got in the car it was freezing and my windshield was still iced over. What good is remote start besides getting your engine warm?
Thanks
TheDarkKnightKnox
Columbus, OHIO
Here is a quote from a previous post i replied to regarding this questions.
you'll need to check your vehicle settings for the heated seats here's some info from the manual. Something to remember: The temperature of an unoccupied seat may be reduced.
Remote Start Climate Control
Operation: For vehicles with the
remote vehicle start feature, the
climate control system may run
when the vehicle is started remotely.
The system uses the driver's
previous settings to heat or cool the
inside of the vehicle. The front
heated seats will turn on if it is cold
outside. The heated seat indicator
lights do not come on during a
remote start. See Remote Vehicle
Start on page 2‑5.
Remote Start Heated Seats
When it is cold outside, the heated
seats can be programmed to turn on
automatically during a remote
vehicle start. The heated seats will
be canceled when the ignition is
turned on. Press the heated seat
button to use the heated seats after
the vehicle is started.
The heated seat button lights will
not turn on during a remote start.
To program the heated seat feature
to enabled, see Vehicle
Personalization on page 5‑34 for
more information.
Remote Start Auto Heat Seats
When on, this feature will turn the
heated seats on when using remote
start on cold days.
Press the MENU/SELECT knob
when “Remote Start Auto Heat
Seats” is highlighted to toggle
between “On” or “Off.” PressE
BACK to confirm the selection and
go back to the last menu.
