Genuine GM Engine Zero Miles
Uluz2a6
2010 2011 2012 2013 2014 2015 2016 2017
Equinox Malibu Terrain 2.4 Direct Injection
Fully machined Zero miles.
Not a used engine with unknown history
This engine has been built with all genuine GM parts from the factory.
Part Number Quantity Description
12605565 1 Oil filter kit
12584041 1 Crankshaft seal
12680750 1 Timing chain kit
12649233 1 Balance chain tensioner
12635427 1 Balance timing chain
12620540 4 Iridium spark plug
12611196 1 Head gasket
12609291 1 Valve cover gasket
12622410 1 Thermostat
24435052 1 Front cover gasket
12591866 1 Rear main seal
12591093 1 Rod bearing set
12591092 1 Main bearing set
12646457 4 Piston
12621505 2 Camshaft Actuator
12572638 16 Lash adjuster (lifter)
12659419 4 Piston ring kit
12630084 1 Water pump
Block measured and machine honed. Crankshaft polished. Cylinder head fully refurbished (valve stem seals, guides as needed, valves as needed, valve job, milled). All parts hot tanked to remove everything from oil and coolant passages. Oil pan, valve cover, front cover, and water pump outlet cover were blasted to remove any scale or debris. Engine rebuilt and torqued to GM spec.There no aftermarket parts in this engine.
The pistons and piston rings are the new updated spec that corrects the oil consumption issue in Malibus, Terrains, and Equinox engines.
Warranty included
All receipts for parts and machining included
Installation available
Price varies based on year make and model as well as your current engine's issues. Does it smoke? Knocking? Seized? Hole in block? Timing issue? Send me a description of whats wrong as well as the year, make, and model and I can provide an estimate.
ullwn
Saw this posting.
What is the cost for a new engine?
Please advise?
Joseph
