Fog Light Install
JustMonicaEqui
Florida
Hello, first post long time lurker. But I wanted to share for those looking to install after market fog lights a little bit of insight.
I have a 2024 Equinox LS 3rd gen, and hated the fact it didn't have fog lights and waited a year and some before I finally came across a set that looked sharp and stock.
These Are Spyder model# FLCEQ22LEDC, which you can google and find, I bought my set on eBay for sub $100.
I'll do my best to post below a bit of info as far as the install goes. Keep in mind I have tiny hands, and the driver side was tight to work on.
So the tools I used was mainly t15 for removing the screws from the wheel well cover to pull back and access the FL covers. And the 7mm socket for the rest of the light housing install. (The kit to the right has been a life saver because you can make it as tiny or as long as needed to get into awkward spaces and ratchet away!) (Got it on Amazon)
So once the wheel well cover was pulled back I popped the side marker light out to make a bit of space. I tried to get pictures of the 4 bolts to remove the FL Cover so you know where to look. (Circled in orange)
The two inner bolt head screws once the fog light assembly goes in are going to invisible, especially with the windshield washer reservoir in the way. So with my tiny hands and that little ratchet was the only way I was able to screw the assembly in.
Anyway once the FL cover is removed and you remove the two tabs holding the wiring, your just going to take your time slowly sliding the assembly in to the space from the wheel well, at that point I used the front opening in the bumper to pop the two tabs into the foglight assembly before seating it and securing it in place.
(Originally did the passenger side first but the driver side was harder so most install interior images are from driver side) (thought about making this thread after I did passenger lol)
Anyway, on to how I ran the wiring!
So while I had both fog light assemblies installed, I seen a good space following another wiring line to the right of the fuse box, in front of the battery, and to the left of the windshield washer reservoir and was able to pop them straight down. (Zip tying it to the other harness just to secure it, after ran)
As I pulled it through, wondering how I was going to get the line to the passenger side, I figured the easiest way was to unscrew the cover from the bottom and run it along to the otherside. Which saved headaches and took minutes.
And boom! We're out on the passenger side and plugged in!
Secured the plug in place, screwed the bottom panel back on and reinstalled the side marker and closed up the wheel well on the passenger side. Then went and repeated the same on the driver side. Assemblies installed, and wires ran to both ready for power!
Now I'm not going to go into wiring everything up, that's gonna depend on your kit or if you even go with these lights. This kit does come with a switch is the way I decided to go, as I don't want to tap into any wires or void any warrantees. But I'll point you in the direction of where the firewall gromet is located (took me forever to find it when I wanted to run my Kicker Slim Sub last year).
To be continued.... ran out of picture posting room!
JustMonicaEqui
Florida
Continued...
So on the driver side your going to pop and remove the step/wall panel that's next to the left foot rest. Your going to pull the carpet to the side and reach up and pull the padding as far as you can without damaging it to the right. With a flash light your going to look up behind the dash and you'll see a big gromet with the main wire harness coming through, I found it easiest to pull at it from the top and work your way around to open it up.
As I did so I just used a thick 4g wire I had to fish through the firewall, and it ends up just behind the coolant reservoir ball (which I removed and pushed to the side to access everything easier) taped the plug on and simply pulled through what I needed and pushed the gromet back into place.
Fortunately for me I hardwired installed my dashcam, so I grounded the switch to the chassis, and piggy backed the accessorie wire to my dash cams hardwire for when the vehicle turns on. After the switch was hooked up, and the power was ran I was finally done with my install and now enjoying my fog lights...
Lights off...
Lights on...
And yes I also have a interior and exterior Govee lighting kit, because I'm just that king of girl...
Other things I've added to my lil equi is running boards (the dealership got a kick of it, they busted out their phones taking pictures, but loved the look lol). Afe Pro Mesh Intake filter (dry medium, no oil). 1 10inch Slim Kicker Sub. Two tone black and grey leather seat covers because I absolutely love the grey and black cloth interior, but don't want it destroyed. Had it ceramic tinted 20% all the way around. Blacked out the bowtie front and back, and smoked the sidemarkers (because the orange just looked gross). After market led reverse lights (which are extremely bright and great at night when backing up), and led license plate bulbs.
Anyway, hope this info helps someone! Sorry it's my first semi tutorial and know I missed alot of little things. But just wanted to give the info I was looking for when thinking about installing these fog lights.
Rocky
@JustMonicaEqui
Great respect for your outstanding post. Thank you for your time putting this together and sharing.
I also have a 2024 LS and wished Chev had at least made Fogs / Driving lights an option.
JustMonicaEqui
Florida
@JustMonicaEqui
Thank you, much appreciated! And Same, I never had a vehicle without fogs and was strange that it wasn't an option, even though the LS is considered more of the stock version.
Scouring the web, I hated the blue and orange goofy looking options that were available at the time, I didnt want turn indicators or colors. But I have to give Spyder their prop's for making a beautiful stock looking housing with no gimmicks. Truly looks like factory And keeps it classy. (Sounds like an ad lol but isn't, I literally looked for assemblies like these for a year and half!). Just really happy with the outcome in the end.
Well-known member
Excellent write up, thanks for taking the time and sharing! I had thoughts about installing fog lights on my 2022, someone had posted about some he found on Amazon that looked decent. Still toying with the idea ..... these are a little pricier as they have sequential LED turn signals
Front Bumper Fog Light Turn Signal Assembly Daytime Running Lamp Compatible With Chevy Chevrolet Equinox 2022 2023 2024 LS LT Fleet RS Premier​
Brand: BINQIGOO
JustMonicaEqui
Florida
Brand: BINQIGOO
Thank you, I kept looking for more in depth videos or tutorials and couldn't come across anything. So decided to post some of the info I was looking for!
Those lights aren't bad at all, it's around the price range of the ones I went with, I just wasn't interested in the turn signals for my self. I just wanted more light! Hope your install goes smoothly! Any questions I can help with, I will!
