Engine power reduced
Tele-trucker
2012 Chevrolet Equinox 2.4. Engine power reduced and stabilitrac message. Scanned codes. P0016, p0089, p228d fuel pressure regulator. Fuel pressure too high. A lot of people said they had this message, cleaned the throttle body and it was fixed. I cleaned throttle body. Started the car and it ran rough for 10 to 15 seconds and died. Now car will not start. Obviously not throttle body issue. The part on the fuel rail that looks like a fuel regulator is called a high pressure fuel pump. Seems that the regulator if there is one is in the tank with the main pump. Weird design. I don't want to buy parts that I don't need. If the fuel pressure is too high it seems that the high fuel pressure pump is working or it would be too low. Any ideas.
turoacosta
Hi Tele-trucker,
Did you solve your problem? I am experiencing similar problems.
turoacosta
Did you solve your problem? I am facing similar problems.
