emission control
sspeechly
I took my car to the chevy dealer and they said I need part #12610560. I ordered it and gace it to my mechanic, He can't find where it goes. any help?
Colt Hero
If that’s the EVAP purge valve, and this is a 2011, look behind/under the throttle body along the firewall area. It’s held in with a single 10mm bolt. There’s a single power plug and the valve itself plugs into a bore/hole. You’ll have to remove the “accordion” air hose/pipe to then be able to reach around and under with your ratchet and 3” extension
