Date of Manufacture
bowtieman
Chandler, AZ
When you open the drivers side door bottom right hand part of the body. Near the tire pressure specs, ttheir should be a silver rectangle sticker with black font. This will tell you the born date and vin. Just month and year. Hope that helps.
SCCUBSFAN
Anderson, SC
Thanks. I was looking for it on the same area that the tire specs were not below it. Just like to know if there are any TSBs for it.
2010BlkGraniteNox
Viera, FL
Take the VIN to your local dealer service/parts department and ask them to run a Vehicle Inquiry (this will give you all options and your actual build date, i.e mine was 3/12/10) then to check in the system for any open bulletins. It would take the person just a few minutes to accomplish both for you
Member Recommended
