A week ago I needed a jump start I thought I accidentally left something on and didn't give it a second thought a few days ago I go to get gas shut it off and came back to leave and the battery was dead again tried a jump start and couldn't get it to start the battery is from 10/22 so the battery should be good so I thought I took the battery to be tested and it failed so I replaced the battery and noticed my battery voltage was low 12.2 volts it would occasionally go up to about 14 volts and fall off to 12.2 volts I thought maybe the alternator was bad and replaced it with a used one I'm.still experiencing the same issue I noticed that if I have my headlights on the voltage would go up and then slowly drop down to 12.4 volts again if I coast down a hill the voltage comes back up to around 14 volts and then accelerate and the voltage drops again the car has only 55k miles I don't have any warning lights i checked the mega fuses and the little 5 amp fuse by the battery all checks good so im.wondering if the current sensor is bad and that's my problem? I have a decent scan tool and nothing about the battery or charging system comes up I'm going to check the connections at the alternator to make sure I have the battery voltage and the signal from. The bcm so any ideas or inputs would be greatly appreciated or further information is needed let me know thank you
