Great Question and of course, I don't have an answer however, I have been watching this podcast and this guy does in depth analysis of what might answer your question. The podcast name is called 'State of Charge' and he not only owns and tests virtually every EV charger but I think also owns a 2024 Equinox EV and here is a range test for the 2024 Chevrolet Equinox EV 70mph range test.
and here is a list of all of his videos:
https://www.youtube.com/channel/UCdX0BJNon1c6GfOdeS3pyDw/videos
We own a 2024 Equinox EV 3RS AWD and after watching a bunch of his videos (and others) and even though we charge (so far) 100% of the time at home (we charge 20-80% and btw, the 'scheduled charging times' or 'charge later' does not appear to work and ONSTAR (24/7 free support specifically for EV's) as well as 'My Chevrolet support has no idea that these two do NOT work and since our electric provider has us on 'Time of Use' which costs double if the car charges at times NOT considered 'OFF Peak', you may want to watch for this and so I am replacing the LEVEL 2 'TESSAN' charger (I DO NOT RECOMMEND THIS AT ALL) I ordered this charger (that the 'State of Charge guy' gave a score of 98 out of 100 on) and this charger (the EVIQO,
EVIQO EV Charger Level 2-48 Amp Level 2 EV Charger Hardwired, 240V Electric Vehicle Charging Stations, J1772 Chargers 11.5kW, Wall EV Chargers for Home, EVSE EV Charging Station 25' Cord because this has a mobile app that you CAN set specific charge times
We only charge to 100% occasionally, once or twice a year, when my wife drives from Pittsburgh to Erie and since the Equinox AWD only gets 286 miles at (100%) charge and we only charge it to 80% normally (we are retired and want to maximize battery life) based on advice from the fellow at state of charge, in case my wife needs to go somewhere when I am traveling I purchased from Amazon the below 'Tesla charging adapter' in case she has to use a Tesla type charging station "
for Tesla to J1772 Adapter with Screen Display [Only to J1772], 60Amp 250V Converter with Press-Lock, Compatible with Tesla Charger Connectors, Destination/Mobile Chargers https://www.amazon.com/dp/B0CYPM1Q2R?ref=ppx_pop_dt_b_asin_title&th=1
Finally, if you really want to have instant answers to every aspect of your EV battery/charging/range health, etc., I purchased this monitoring tool that plugs into the OBD (On Board Diagnostic Port) of the Equinox EV
TOPDON TopScan OBD2 Scanner Bluetooth, Bi-Directional Scanner Wireless All System Diagnostic Tool for iOS & Android, 8+ Hot Reset, Repair Guides, Check Engine Car Code Reader, Performance Test , https://www.amazon.com/dp/B0C3QQYQ1B?psc=1&ref=ppx_pop_dt_b_product_details $56.99 on amazon.
Here is a list of a ton of great reviews on the scanner if you are interested: https://www.youtube.com/results?search_query=TOPDON+TopScan+OBD2+Scanner
Hope that helps. Any direct question, my email is [email protected]
Tom Lawson
