AWD issue
dadzilla15
2010 2.4 Ecotec. When making a hard turn, left or right AWD is activating and right rear wheel is activating causing a shudder. Removed fuse from AWD and the problem goes away. Connected scan tool and when checking AWD I am only getting signal from the right rear wheel, other 3 wheels are registering "0" mph. I am assuming the AWD system uses the same sensors as ABS which does not have an issue. My question is where am I losing the signal for 3 wheels AWD if ABS is working properly?
DawnFM
Try to make replacement of oil of a distributing box, when it was changed last time?
