Any Research on Best Engine Oil For Turbo
daveg95harley
Broomfield, CO
yea my manual says dexos 1 Gen 3. My Research Shows the natural gas Pennzoil Ultra Platinum or Mobil 1 Full synthetic dexos 1 gen 3. Due to bombings in Qatar, UAE, Bahrain. The Natural Gas Based Oils From Middle East Facilities Have to Rebuild Parts of Refineries That Produced the NAT Gas Blend Will Be Back on Line by MAR 27
Not sure where you’re located - but you can’t go wrong with the correct ACDelco oil.
I prefer to run Valvoline Restore & Protect in my 2021 with the LYX 1.5. The goal is to keep the piston rings packs free and clear and to keep the overall internals as clean as possible. Any tear-down videos I've seen of these engines, they all look bad on the inside. Lots of varnish. Plugged up rings, etc. Of course you don't know the whole story of the engine, but if you follow the oil life monitor down to 0% on every oil change, you are going to have problems IMO, even with Dexos rated oil.
renossuv
I have a 2019 2.0T. I’ve been using Costco Kirkland 5W-30 as it meets the Dexos 1 Gen 3 spec. SUV still running strong and pulling a travel trailer 4x a year. I change my own oil around 30-35% oil life using an AC Delco PF64 filter.
Well-known member
I also use the Kirkland from Costco, 0W-20 on my 2022. Great price and it meets all the specs - i had heard whose oil it is, but forget.
RIT333
GaryM. What is your basis for that bold statement? It may be right, but how do you know for sure ?
GaryM
Personal experience and research. There are a number of credible resources that will help with the details. For years Mobil 1 products (I use their engine and trans fluids in my 2025) for years, have been known for their oil product quality. I was field service engineer for a major diesel engine manufacturer and director of fleet reliability and development for a major trucking fleet during my career. Mobil products always come to the top of the list for performance. I restored a Corvette and only use Mobil products. Runs like new. You might wonder why I have replaced that ATF with Mobil ATF in a new Equinox. I live in a cold climate. My 2018 Equinox had a ATF temp control system that used the engine coolant to preheat the ATF for cold weather shift performance. 2025 doesn't have that so the ATF must be able to flow in cold weather until it warms up on it's own. Below zero it doesn't so the 8 spd never gets above 6th gear. Mobil ATF has better flow characteristics than the GM product in cold weather. It's an approved product by GM. It also has better anti-corrosion characteristics. I hope that helps.
Alan47717
Marana, AZ
Teardown engine videos usually have a couple of things in common, something broken and poor maintenance. The properly maintained engines are the ones you buy from the salvage yard, removed from a junked vehicle, to replace the engine you see in those videos.
Member Recommended
