Marzoo
Both Onstar blue button and android navigation will not connect. Apple car play navigation works ok. Tried a reset but that does not help.
Made an appointment with the service departmentSuggest you see if the locator on the map is accurate to where you are. There's a telematrix module that's been failing. The first thing you see is OnStar not working, it can't pinpoint where you are. The other indicator is the display doesn't show posted speed limit any longer. I had one fail not long ago.
Here's the history of my OnStar module saga:
12/22/25 - OnStar module failed.
1/14/26 - Appointment at dealer. Verified module was bad. New module ordered, on back-order at least two weeks.
2/5 - New module arrived at dealer.
2/10 - New module installed at dealer.
3/18 - Received message on info screen: OnStar service has expired!?!?!? WTF! Apparently I was on a trial plan with the new module and my eight year OnStar Basics plan was never updated with the new module.
3/18 - Called OnStar support. Issue opened.
3/24 - Called OnStar support. No update on issue. Issue escalated to level three. Receive a 30 day trial for OnStar One plan. Trial set to expire on 4/23.
4/10 - Called OnStar support. No update on issue.
4/20 - Called OnStar support. No update on issue. OnStar One trial extended another 30 days to 5/23.
4/30 - Called OnStar support. No update on issue. Recommended dealer visit.
4/30 - Visited dealer and discussed with service manager. He said OnStar service was terrible. "I know who to call. It will be fixed by the end of the day." I'm still on the OnStar One trial until 5/23.
5/18 - I noticed that the OnStar One trial was somehow extended a third time to 6/12 and my eight year OnStar Basics plan was extended by 14 months to 5/12/2034!?!? Another WTF!
There were also several calls to OnStar via the On Star button in the car.
So, I still don't know if my OnStar Basics plan is fixed or not. I'll have to wait until June 12 to see. I really DO NOT want to call OnStar support again. If it's not fixed, I'll go see the dealer again.
Yes I had the same issue, no maps or Google. Press the OnStar button and see if they can give you your current location. I was in front of my home and they had me miles away. Needed a new module and that put me back in business.Both Onstar blue button and android navigation will not connect. Apple car play navigation works ok. Tried a reset but that does not help.
The part will probably be on backorder. Mine was for quite some time. Good luck.Headed for service today
Yep. I'm in the 9th week of waiting for a new module. No word on when it might show up at the dealer.The part will probably be on backorder. Mine was for quite some time. Good luck.
My OnStar One trial ended on 6/13. My OnStar Basic is still working! YAY!Here's the history of my OnStar module saga:
I wish I would have talked to the service manager at the beginning of this mess instead of the useless OnStar support.
I decided to try the infotainment reset. Apps and navigation are now working again. What a fup'd system.Dammit.... Google navigation stopped working today... "I'm offline" message. Amazon Music app stopped working. Back to square 1.
Call Onstar from your car. You may be having trouble with the communication module. I did and it can cause a bunch of different problems.Both Onstar blue button and android navigation will not connect. Apple car play navigation works ok. Tried a reset but that does not help.
Make an appointment at the dealership. I had this problem about 5 months in on my 2025 Nox. There was a big problem with the communication module. It can cause a lot of problems. I had to wait for one but I think they are available now. Mine had my Onstar location about 3000 miles from my actual location.Both Onstar blue button and android navigation will not connect. Apple car play navigation works ok. Tried a reset but that does not help.
