2023 Equinox RS flat towing issues continue
Armyhockeynut
We have been flat towing our 23 Equinox on several trips following the "updated towing procedures" that GM sent out last year or so.. It seems every time we do the disconnect, we encounter different scenarios. We turn everything off when we hook up, but at disconnect, the radio is on. Recently the wipers had turned on, and the lights. Several members have commented they get a message telling them to roll down the driver window and back up. We have gotten this message very rarely. Most of the time we get the ESC Service light that eventually goes out after we disconnect and drive around a bit. We also get a warning from our MyChevrolet App that says the car battery is critically low and to start the car.
Per our installer's recommendation, we do not have a charge line installed.
Per the GM instructions. we have a battery disconnect on the negative terminal that we disconnect as part of the towing set-up
If I install a charge line for our DEMCO Stay & Play from etrailer, how and what do I need to do about the battery disconnect?
Need to get this figured out before some longer trips.
Thanks.
4549stiltz
Washinton
I have a 24 Equinox that just recently bought. I set it up tow I have had zero issues. After hooked up I just put the shifter in neutral and push the button to kill the engine but of course the engine dies but the radio keeps playing because the switch is in Access mode. I then disconnect the battery. I have a simple knife style switch on the battery. When I unhook from MH I reconnect the battery and start the engine and yes it says roll down the window. I do not have a charge line to the battery it cannot go dead if it is not hooked up. This is no different than if you had to replace the battery. I have a separate line from the MH to service the brake control; system.
Kmac
Nashville
Thanks.
You will need to find another RV mechanic familiar with flat tow upgrades to look over what the first installer did.
4549stiltz
Washinton
Instead of running a charge wire to the battery I ran it from the MH to inside of car with a connector and the ground from the 7-wire plug so I could plug in my brake controller that way you are not messing with car electrical system. Just be sure to install a fuse at the source of power at MH. I just added the power wire to my MH battery Plus
