2020 Door Locks not working from FOB, auto lock or interior buttons.
apr67
So I can't lock the doors on Equinox via any method. Passenger door/drivers door won't lock or unlock from the FOB, from the interior buttons, from the door button, nor when I put the car in drive/park.
Fob works to open hatch. I've unplugged the battery for 5 hours, no change.
Any ideas?
Just as an aside, I have another electrical problem that started a month ago, and that is the auto lane keep and forward crash sensor is doing nothing. I doubt that is related, because it happened at different times. I am about fed up with this car and its electrical system that must have been designed by Mopar.
Well-known member
do you still have the original battery? If so, that may be the issue
apr67
Why would I not be able to lock the doors from the interior buttons? And the fob still works, like I said, I can open the rear hatch with it.
(And the battery was replaced 6 months ago with a name brand).
bearbait
Any ideas?
I have a similar problem with my 08 Nox. Fobs stopped working and some doors work with door switches, some don't. There is supposedly a module which controls these functions and is only available at junk yards. Don't need to lock it so I'm not going to bother with it.
apr67
Sorry, I should have closed the loop on this. My problem was a wire from the fuse box in the engine compartment according to my dealer.
Ron Hertzog
Ellwood City, Pennsylvania
Probably one of your door lock actuators went bad. I have had to replace all four of mine at different times since I bought my Equinox in 2019. Is the little red light lit up on the door lock buttons? Usually, a sign if one it out. I have posted my door lock problems on here, check them out.
TopHat
Do look at what fuses handle the doors etc. Sometimes you can't see a burnt out fuse. Switch the fuse out with same amp fuse; can always buy a fuse if it is the problem.
