2018 lt alarm...
beir
Michigan
Just picked up a 2018 lt, and was wondering if can alarm comes as standard equipment? Small red light comes on ,on top of dash but if ya shake car the alarm doesn't go off. Tried setting menu but nothing on it about alarm. Any suggestions?
Brennb
I have my 18 set up to lock the doors after a brief period, after leaving the car. If the passenger tries to exit after the doors have locked, it sets off the alarm. The alarm won't go off by shaking the car.
beir
Michigan
Thanx for the reply, I'll give it a try, this car is for the wife and she has some trouble with newer technology (me too...lol) can the sensivity be adjusted? Car only has 49k on it and trying get it set to where she likes it, thanx for the reply...
Brennb
I had an incident 2 years ago, that shattered the rear window. The alarm didn't go off. A neighbor's friend, parked on the street, remote locked his car, and set off my alarm. I have no idea how it works, lol.
What you are describing is the standard theft deterrent system that GM puts on all of it's vehicles. It doesn't work like an aftermarket or higher end system. There are no shock sensors, etc. I believe on some of them, the horn will blow if a door gets manually unlocked w/out opening the door first.
Moonwink
SW of St Louis, MO
My daughter's Sonic was set to automatically lock her doors. One morning she opened the hood to add some anti-freeze and the darn thing locked her keys and phone inside on the seat. That led to a disaster when she cut her arm breaking into her house to get to the spare set of keys. My advice would be to disable the auto-lock feature and never use it.
Colin Lister
My nox'18 won't auto lock the doors if the fob is inside. It will deep twice.
I did find that if I leave the keys inside and don't shut the doors for several minutes, the horn won't beep at all, but the doors won't auto lock either. (could be a problem.)
I do have the door lock set to beep once when locking just be sure. Usually about ten seconds after leaving the car.
rawhite318
I have the same model. It’s not an alarm. It’s a keyless entry. You can lock the doors open the doors,roll down the windows, and open the hatch if that is an option you have.
