2018 Equinox 1.5L Ecotec Throttle Body Retainer Clip Question
Lugnut
UPDATE: I saw a YouTube video of the installation of that clip. All is good.
Hi all, I need some of your expertise. I have a 2018 1.5L Ecotec. Cleaned the throttle body and reinstalled with a new gasket. Torqued bolts to 89 in-lbs. Installed large air tube but before I screw this up, I have 2 questions about the metal clip and plastic retainers. I know the clip goes on with the end prongs sticking up and the plastic retainers snapped in under the metal clip.
Here's my 2 questions about reinstalling this clip:
1. Since the plastic retainers have a tendency to fall off, is there a trick to keeping them in place, e.g., small blob of grease, chewing gum, zip ties, or maybe something else not so ridiculous.
2. Does the clip just snap on by getting pushed in on the large air tube. How should it be reinstalled?
Thank you for any help.
Brennb
Southwest Michigan
Can you supply a link to that? I'm curious about that clip too
Lugnut
See if this link works. It shows the reinstallation but not the removal. Just ease it out slightly with a screwdriver. You do not need to remove the clip completely. If you do, put some towels all around because the plastic retainers WILL fall out.
This video show how to ease out the clip with a screwdriver.
I didn't realize those plastic bits on the U-clip existed. Are they falling off for you?
