2017 equinox bent metal under antenna base leak
tbu
Hey,
I backed up into the garage door when it didn't fully open. The antenna caught the bottom of the door and snapped off of the base. The metal on the roof around the hole for the antenna base bent upwards.
I've flattened the metal as best i can. I also installed a new antenna base, but there is a leak now.
I took the new base off again and applied some waterproof silicone sealer, but there is still some water coming through.
What are my options to fix this?
I found this: https://www.amazon.com/Gorilla-4242501-Epoxy-Putty/dp/B07PGKYF5X/ref=mp_s_a_1_3?dchild=1&keywords=gorilla+epoxy+putty&qid=1596944653&sprefix=gorilla+epoxy+&sr=8-3
Do you think a bead around the roof opening will solve the problem?
