ok i came accross this froum thread on teh travers site and you may have seen it but just in case i did send the YT that is in this forum link so you may omit that video but it is the last of the thread. in this thread on guy gives some help with what pids to look for if you have a scanner that can take them. for the most part as i said you most likely have a wire issue or you have a bad HP pump or sensors. on thing did you put a gasket on the HP pump when you installed it or just use rtv? if you used rtv you that may be the issue as the gasket gives the HP pump the correct distance from the intake cam lobes and if it sets to close it may be getting the high pressure form over stroking the HP pump.
2012 Terrain 2.4 P0089 and P228D
www.scannerdanner.com
here is another one that may be more related as it start out at the p0089 and p228d code
Intermittent P0089, P228D 2011 Chevy Equinox 2.4 AWD
also i found this one that relates the vvt solenoids so if youhave yet to change them then follow this forum thread ands see the photos he posted. if you have yet to inspect them then that just could be an issue as if they do not send oil to the phasers then the phasers do not move and can give the p0017-17 codes
Hey all, I joined just to ask this question! I am dealing with an issue after a recent transfer case replacement because a bearing exploded(done by me). After getting it all back together, I started the Nox and it was idling very rough and eventually threw a CEL and starting chugging really...
www.terrainforum.net
this 2nd thread the issue was the cam phaser the 3rd thread is the vvt solenoids.
yea i know losts of info but try to check some out and they may help you figure this one out. also like i say if you got your chain set from ebay and decide to change it out again go to cloyes. i had to as the ebaset failed in 6 months.
good luck
