corvairbob
- Joined
- Oct 19, 2021
- Messages
- 199
- Reaction score
- 20
i have my 2.4 torn down in the shop. i need to know if anyone has done a repair the equal the newer ecotec engines that i hear did not use the oil that the 2013 engines used. if so what was it so i might do the same fix?
i have to get rings and rod bearings. i'm not splitting the block for mains as the rods look good. and # 2 and 3 had .003 on the plastigage check. i did not do #1 and 4 as i had the head on and the timing chain off. that was the original reason i had it in the shop.
anyway, my girl said that she put a gallon of oil in it a week. for the last 3 years that she had the car. i did not know she used that much oil and the reason i got it was she had it in another shop for repairs that turned out to be timing chain and they wanted 2100$ that she did not have so dad got it. being i have done my share of engine work and old car restores she figured i could help her out.
anyway i now have for the top of the piston 3.43 on all 4 and for # 2and 3 rods with the caps finger tight i have 1.936 so i have to find out if that is a standard journal and bore sizes? the rest i can figure out.
it sure would be nice to find out how to make is so it will not turn into a oil user again. i'm hoping some have found the fix. thanks for any help. bp.
