08 Equinox - overheating issue (no leaks)
Revvingchevy
Hi everyone. I'm new here. Been driving an '08 Equinox 3.4LT for about 8 years and it's been a great value for the money. I topped up the coolant 2 days ago before going on a 90 mile trip. After driving over 30 miles at highway speed. I saw the gauge rising and pulled right over. Once cooled down, I checked for leaks, nothing. Oil and reservoir look OK. So I drove it home slowly, stopping two more times to cool, when the gauge rose again.
No white smoke is blowing out the back and no leaks are apparent. The engine sounds normal with normal power, starts fine (plugs were recently replaced).
Note - on one of the return trip stops, it sounded like a small animal was poking around under the firewall. So I figured maybe there's an air pocket, probably I should have let it idle a bit with the cap off, after I topped up the coolant? Just a bit of bumping and gurgling sounds.
Note - My heater core is working but will eventually need replaced (minor smell sometimes when using heat but no film on my inside windows)
I took a different vehicle on my trip a couple of days ago, then today I went out to look it over again. Checked the oil. Oil looks normal, oil level is ok. No chocolate milkshake oil. Oil cap looks ok, not covered in goop or sludge. I took the coolant cap off then started the engine, hoping to help release any air pockets. Went inside the cabin and revved it and let it idle for 5 minutes. Coolant temp showed normal. Placed the cap back on and went back into the cabin for another 15-20 minutes. After about 15 more minutes it started to rise but not overheating. If I revved the motor, the coolant temp gauge would begin to go down. I did this a couple of times and it did not rise to overheat, as long as I revved it a little. So I didn't get the Overheat /AC Off message today. Took a look at the coolant reservoir and it is clear, not dark or cloudy. I think the gurgling noises have decreased since I idled it with the reservoir cap off. I have a basic diagnostic tool that I plugged in. I got no error codes relating to the coolant system, only one misfire detected.
The only time the temperature has risen previously is if I am in a busy drive thru line in July, and the line is moving too slowly. In that case I'd shut it off until I need to move ahead. As long as moving, no overheating.
I don't think i have a blown gasket but could it be still? Or is a more likely culprit the coolant temp sensor and/or thermostat?. A couple of years ago I had an issue with not getting enough heat. They said they flushed it out and a lot of sediment or something (scale?) Can't remember the exact word, came out. But since then it has run fine and the heater works great. I'll get my mechanic to take a look, just thought I'd ask online too. I've really enjoyed driving this thing especially during winter. Great for hauling stuff plenty of power to suit me, handles nicely in snow. I even stuffed a large snowblower into it (after unbolting the handle) which amazed the store I bought it from. Thanks in advance for any opinions!
Revvingchevy
Update - I took the Equinox for a 7-8 mile highway round trip today. I drove highway speeds and it did not overheat at all. Parked it, opened the hood and everything looked normal. Coolant reservoir normal. I think I might have had an air pocket in it the previous time I drove it. Before leaving that time, I had topped up the coolant, and put the lid on without running it a few minutes first. I think that caused an air pocket /overpressurized the system.
Guess I'll drop it off at my mechanic and ask him to look it over while doing a couple of other "regular maintenance" fixes ( I need at least one front bearing replaced). Ask him to check if I need a coolant temp sensor or a new thermostat.
Sorry my posts are long. If anyone has time to read it I'd be interested in your opinion. Thanks.
Revvingchevy
Hi can I get a second opinion. Was my (temporary) overheating issue potentially caused by an air pocket, from not bleeding the system when refilling coolant? Hoping to get another opinion before taking it in for other work.
vboss5764
I can tell you with almost 100% certainty you have a leaking head gasket. Very common for the 3.4, stop driving it immediately.
Revvingchevy
I used a bottle of rislone heavy duty gasket sealer. I flowed the instructions very closely. That is an excellent product. It enabled me to drive it for about 500 miles (gentle driving) until I got the right headgasket kit and scheduled an appointment with my local backyard mechanic to replace the headgasket. I thought it would cost closer to $2000 but it came in less than $1500. It was worth it to us due to the condition and relatively low mileage on it. Just over 200km. Much cheaper and less hassle than getting another SUV. Plus we really enjoy driving it and it's had no other big issues in 8 years of driving. So if you're going uphill on the highway and it starts to overheat it is likely a failing gasket causing exhaust gases to heat the coolant.
bearbait
My 2008 Nox has 120k+ on it and runs like a new one. I flush antifreeze every 4-5 yrs. I believe this helps with the head gasket problem. Am thinking of getting a Blazer with the 3.6 but have been reading about problems with them. I guess every car has its quirks!
I’m working on latest project. 07 with bad headgaskets. Seller mentioned he did them before. I did find 1 cyl had a chunk of gasket missing and pushed out fire ring. Who knows?
Revvingchevy
Cool. If that is 120k miles that is a bit less than mine has. I also like driving it in summer when I throw some good sized summer tires on. It handles nice and it is great for driving in snowstorms.
