07 torrent(equinox) with cyl 6 misfire.
Wazzappenning
Hi new here and looking for help. Ive checked the following and they check out. I have spark, checked that injector is firing by putting screwdriver to it then ear to end of screwdriver. It doesn't seem to misfire when cold but after warmed up it does. That leaves me with heat causing the wires or coil to have issues or intake manifold gasket as heat would warp it. I was wondering since 6 and 3 fire at the same time off the same coil ( i believe) one on compression stroke and the other on exhaust stroke to burn off excess fuel vapors, could i swap the 2 wires at the coil and see if the code goes to cyl 3 intead of 6? Or are the sparks not equal or could cause issues?
