Fog LIght wiring and LED Headlamp Queston
This is a discussion on Fog LIght wiring and LED Headlamp Queston within the Exterior Modifications forums, part of the Equinox, Terrain & SRX Modifications category!
I installed the fog lamps, found out I had to replace the complete lighting wiring harness? Anyone done this yet? ...
Old 09-28-2015, 12:10 PM   #1 (permalink)
frhrwa is on a distinguished road
Default Fog LIght wiring and LED Headlamp Queston
I installed the fog lamps, found out I had to replace the complete lighting wiring harness? Anyone done this yet? How tough is it, there are a bunch of connections.. then I understand the dealership has to program the computer to make the fog light switch on the lever work? next, are there any Headlamp (complete unit) with LED strips and LED lights or halogen, available.. can't seem to find any to replace these stock ones..
frhrwa is offline   Reply With Quote
Old 06-19-2016, 09:57 PM   #2 (permalink)
3fingers is on a distinguished road
I bought a Recon lighting kit and it was a simple plug and play procedure no need to alter the wiring/harness.
3fingers is offline   Reply With Quote
Old 06-20-2016, 11:24 AM   #3 (permalink)
dentonnox is on a distinguished road
I did something similar I ran a positive wire which I tapped into the parking lights and then ran the ground inside to a switch so I can turn them off.
Sent from my SM-G900T using Tapatalk
dentonnox is offline   Reply With Quote
2014-2015 Headlamp bulb replacement TEL The Official "How To:" Section 1 09-14-2015 09:33 AM
05 Equinox bright headlamp indicator always on Grisgris8 05-09 Equinox Maintenance 1 08-31-2015 12:33 PM
headlamp off delay empots 2010+ Equinox General Forum 3 09-19-2014 02:14 PM
2006 equinox wiring kwind2010 05-09 Equinox General Forum 5 07-23-2014 07:22 PM
MIL Light, Traction control light, Brake light, ABS light rlrnr53 05-09 Equinox General Forum 3 12-27-2013 06:38 AM
