05-21-2012, 07:28 PM
#10 (permalink)
I'll go this order:
-Check the bulbs if they light up at all functions (hi,low, in this case we know that DRL arn't working)
-Look at the DRL relay if all's ok. You should be able to make it click with a tester (don't know the english term for the thing with a + and - wire that test the power). Look at it physically too because when it's burned it will be all cracked up.
- If the bulb and relay are good, look at the wire between them. Again if all is good I will recommend to test the switch. But I don't think you will reach the 3rd spot !
Let me know !
