Go Back   Chevy Equinox Forum | GMC Terrain Forum | Cadillac SRX Forum > Equinox, Terrain & SRX Modifications > Suspension and Brakes
Brake Rotors Turned.
This is a discussion on Brake Rotors Turned. within the Suspension and Brakes forums, part of the Equinox, Terrain & SRX Modifications category!
Just reporting that my Nox has 61k miles on it and I had a slight vibration while braking. Checked everything ...
  • 1 Post By dietz4ibanez
Old 10-07-2012, 08:10 AM   #1 (permalink)
Default Brake Rotors Turned.
Checked everything and took the rotors to be turned at Sears for $11 each!
A couple easy tips that can prevent this from happening besides normal wear is to make sure you torq your lug nuts whenever you remove a tire. If one lug is tighter all the way around it "can" cause rotor warpage over time. I normally torq my lugs at 125 ft pounds..
They took 6000th of a inch from each side of the rotors. They are installed and the car seems to be braking smoothly again.
Old 10-23-2012, 09:25 AM   #2 (permalink)
I've found a guy here that have really serious price about parts. I've done a brake job on a torrent, cost 70$ cash for the 2 disc and brake pads. Don't know how he makes his money lol
Old 10-25-2012, 05:27 AM   #3 (permalink)
Super Mod
Z_Ghost's Avatar
They look new again.
I bet it stops like new again.
O and I only have 19,000 on my (2011) Terrain.
LOL
92 Z/28
Old 10-25-2012, 07:32 AM   #4 (permalink)
For the torque, the recommended torque by GM is not 100?
Old 10-25-2012, 01:59 PM   #5 (permalink)
It could be. I just always have my torque wrench set at 125 for lugs.
Sent from my DROID RAZR HD using Tapatalk 2
Old 03-11-2013, 06:06 PM   #6 (permalink)
Paul79UF's Avatar
Paul79UF is on a distinguished road
That's what I was thinking.
It seems like most manufacturers have 75 to 100 in the owner's manual.
I've been reading that re-surfacing the rotors is not necessary unless you do have vibration like you stated.
My '01 Grand Prix went 105k miles with the original rotors with perfect braking. They may have made the OEM rotors a bit thicker back then.
I was hoping to get at least 80k on the nox rotors.
My Equinox DIY Guides
Paul79UF is offline   Reply With Quote
Old 03-19-2013, 11:41 PM   #7 (permalink)
It might be due to the fact that my wife is a heavy on the brake.
Yes, Agree, only resurfaces rotors if you are experiencing any vibrating in the brakes.
Old 08-20-2014, 12:18 PM   #8 (permalink)
I'll report this past weekend i had to take the front brake apart. I could tell my rotors were warped however the bigger annoying issue.... Squealing!!!
Turned out the Pads had some built up fragments in the channel, so i cleaned that out, turned the rotors, put everything back together and feels brand new again.
Even better news i've only used 1/4 of the pads in 45,000 miles. Would be awesome to get to 100K miles with factory brakes!
Old 10-06-2014, 09:29 PM   #9 (permalink)
You should be able to get 100k easily! We are almost there!
TheDarkKnightKnox likes this.
Front brake work tallbump 2010+ Equinox Maintenance 6 03-11-2013 05:59 PM
student research on new rotors. need your opinions litebrake 2010+ Equinox General Forum 5 07-01-2012 01:39 PM
Radio is able to be to be turned on without a key . jsfb6pts Audio & Electronics 8 06-19-2011 05:50 PM
Top Center Brake Light slabadie 2010+ Equinox General Forum 4 06-17-2011 07:36 PM
